I have
just now had time to get back to this project.
I was
working this change over back in July.
Frist
just a fast synopsis of the project.
K2CNC
8 feet water cutting table with DC brushless motors and encoders with a KFlop
controller.
The
Kflop was set up with KMotion and KMotion CNC.
We
are changing over to Mach 3 but we would like to keep the KMotionCNC also.
I
have worked with Mach 3 and stepper motors before but not a KFlop.
Current
status
Have
Mach3 homing and controlling the nozzle on (M03) and off (M05).
Up to
testing G-code in Mach3 and simple program worked correctly dry run.
So power
up the pump and ran the program all was good.
Shut
down the pump and did some edits to the code.
Turned
on the pump and I think there was a power glitch it knocked the KFlop off line
had to reboot it and reboot the computer.
So after
getting all items back on line and restarting Mach3 I tried to home all axis.
They
homed the first time but then tried again and Mach3 homed the Z axis and it moved
on to the Y axis.
The
Y axis started to move to the home switch and then Mach3 error then reset.
Stated
looking at this closely and the Y axis was not in the ~home location it should
be.
So I
started up KMotion and use it to home the Y axis and it would home the axis.
But
this home was not located where it was home before.
Before
the issues Y would move over to the switch stop and reverse and move away from
the switch just to the point the switch would turn off home.
But
now after Y reverses it moves away from the switch ~.3”.
Mach3
has to be reprogramed to work with this type of issues.
My boss
that been work with the system using the KMotion.
Tells
me this happens all the time when the system powers up Y axis home in a new
location each time. And this is on the Y only.
What
do we think?
Sorry
this is so long!
Thank
for your time to read all of this.
Tom
